New build, cpu fan stuck on 100%
9 May 2005
Devon
Morning,
Ive just finished my new build and ive managed to sort out all the little problems I have encountered so far apart from this one.
Basically unless I use the Asrock tuning utillity to alter it the cpu fan is on 100% all the time. I have changed the fan setting in the bios to auto from 100% and I assumed this would sort it.
Motherboard: Asrock Extreme 4 gen 3
CPU: I5 2500K
CPU cooler: Gelid Tranquillo.
Any suggestions will be much appreciated.
Thanks
Slack
Hi thanks for the reply,
I found the problem, I set the fan to auto, but the target fan speed to 100% thinking once it went above the target temp the fan would go to 100%. The MB seems to work opposite to my brain :). I've dropped the target speed to 10% and it’s as quiet as a mouse until under load.
Thanks
Indeed :P Do enjoy your new build - just finished my SB build as well, loving it. Such a jump from my old E8500 :D All I need now is the next 3 months off to play everything that's coming out
