- 1 Oct 2007
hi folks.
New pc bits purchased and pc built this evening!
spec here
Vista installed, but i am having a strange problem.
Basically anytime the pc is shutdown or rebooted (including during the windows install process) it just sits there with the monitor light flashing with nothing on the screen, but the pc on.
If I reboot, I get the GFX card splash screen which just hangs, and I have to reset the CMOS everytime. Once this is reset I get the message:
CMOS checksum error - defaults loaded
Then F1 to continue or Del for setup.
But then Windows will load fine!
Any ideas?
spec here
Any ideas?
