OK i need some help, my new build seems to have gone completely **** up. Setup is as follows:
Intel Core i7 920 OEM (not overclocked)
Gigabyte GA-X58A-UD3R REV1.0
OCZ Gold 6GB (3x2GB) DDR3 PC3-12800C8
Samsung SpinPoint F3 500GB x 2
Enermax Noisetaker 600W (from previous build, no issues with it)
Sapphire Radeon 4670 (from previous build, no issues with it and soon to be changed)
Microsoft Windows 7 64bit versioin
Everything was going smoothly until the first windows 7 installation which was stopped by a BSOD. Believing it was something to do with the RAID0 I had just setup and was using for the fresh install i decided to get rid of it and go with a standard install. The second install of windows finished and i was going through the process of installing all my programs and applications and it decided to blue screen on me again.. I've updated the BIOS and all the motherboard drivers (gigabyte website/s are in shambles) thinking it might have been a compatibility issue but still the same stuff.
I loaded up CPU-Z to see if that would be any help and it showed the RAM to be set at 7-7-7-19 timings which seemed a bit off. Thinking i had found the problem i went into the bios and changed it manually to 8-8-8-24 as specified and upped the voltage from 1.5V to 1.58V. About 2 hours later i got another BSOD... I've got no idea what the problem could be now as i know it's not a graphics card issue so i'm thinking some compatibility issue between the mobo/ram and cpu. This is what CPU-Z shows now after i changed the ram timings, maybe one of you guys can spot something.
Other things to note that may be of use are that:
Windows 7 updates install with about 50% success rate and it just says the rest failed to install so i've had to keep repeating the process to get them all installed. Firefox lasts anywhere between 1second to 30min before deciding to crash and apologise to me so i switched to chrome but this is doing the same.
One last thing is i've just tried to install directx and ATI CCC and they just error out at the end...
Any advice is appreciated as i have no idea what the problem could be and not very happy at the way this has turned out at the moment.
