new build, few questions
26 Mar 2010
any chance someone can look this build over? and is there an option anywhere for OC to build this before its all sent out? would be a lot off my plate since it is a whole system, thanks
would also like to know if the motherboard would hinder performance in any way, and which sata slots it has, it just says sata in the specs so id assume 2 cause i dont know what 3 look like :confused:
Uploaded with ImageShack.us
sure? ofcourse not, i cant find decent enough reviews that arent biased towards the more expensive sandybridge processors, saw a few that said they were still more powerful than bulldozer series but still, a budget is what im on so i cant be picky
edit: and what about the rest? whats your opinion on them?
edit: configurator seems to have a few options that arent necessary for what im looking for, overkill in a way
edit: i believe the 1090t would be a much better choice but over the last few weeks it has went from around £135 to £192, and i have no idea why..
If it's mainly for gaming then I'd go with an i3-2120, Z68 motherboard and 8GB of RAM. Yes you wont be able to overclock it but in a year or two if you fancy a cheapish upgrade you could throw in a second hand i5-2500K/i7-2600K or even an Ivy Bridge CPU. Also the 550W OCZ ZS PSU will be more than enough for that system. Better power consumption, less heat, better upgrade path but no overclocking. If the extra cores are important (video editing etc) then consider a Phenom II X6 perhaps.
just need it for gaming really, im not into maxing out settings or overclocking, but the parts listed are a huge leap ahead of my current system which isnt particularly struggling atm but the age shows
also the i3 and a z68 would be more expensive than the ones i have on my list, would it really be that much of a difference?
Just a little more expensive yes.
Your basket
Product Name Qty Price Line Total
HIS ATI Radeon HD 6870 IceQ X PLUS Edition 1024MB GDDR5 PCI-Express Graphics Card **OcUK Exclusive** HIS ATI Radeon HD 6870 IceQ X PLUS Edition 1024MB GDDR5 PCI-Express Graphics Card **OcUK Exclusive** £143.99
(£119.99) £143.99
(£119.99)
Gigabyte Z68XP-UD3 Intel Z68 (Socket 1155) DDR3 Motherboard Gigabyte Z68XP-UD3 Intel Z68 (Socket 1155) DDR3 Motherboard £99.98
(£83.32) £99.98
(£83.32)
Intel Core i3-2100 3.10GHz (Sandybridge) Socket LGA1155 Processor - Retail Intel Core i3-2100 3.10GHz (Sandybridge) Socket LGA1155 Processor - Retail £95.99
(£79.99) £95.99
(£79.99)
BeQuiet Pure Power L7 530W '80 Plus' Power Supply BeQuiet Pure Power L7 530W '80 Plus' Power Supply £39.98
(£33.32) £39.98
(£33.32)
Cooler Master Elite 430 Windowed Case - Black Cooler Master Elite 430 Windowed Case - Black £39.98
(£33.32) £39.98
(£33.32)
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) £35.99
(£29.99) £35.99
(£29.99)
Samsung SH-S222AB/BEBE 22x DVD±RW SATA ReWriter (Black) - OEM Samsung SH-S222AB/BEBE 22x DVD±RW SATA ReWriter (Black) - OEM £16.98
(£14.15) £16.98
(£14.15)
Sub Total : £394.08
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £11.75
VAT is being charged at 20.00% VAT : £81.17
Total : £487.00
Also worth considering a Phenom II X4 960T - a very high proportion are being unlocked to hex-cores and will allow you to overclock too. Should be a bit cheaper too.
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £179.99
(£149.99) £179.99
(£149.99)
(£119.99) £143.99
(£119.99)
Gigabyte Z68AP-D3 Intel Z68 (Socket 1155) DDR3 Motherboard Gigabyte Z68AP-D3 Intel Z68 (Socket 1155) DDR3 Motherboard £84.98
(£70.82) £84.98
(£70.82)
Cooler Master Silent Pro Modular 600W '80 Plus Bronze' Power Supply Cooler Master Silent Pro Modular 600W '80 Plus Bronze' Power Supply £59.99
(£49.99) £59.99
(£49.99)
(£33.32) £39.98
(£33.32)
(£29.99) £35.99
(£29.99)
(£14.15) £16.98
(£14.15)
Sub Total : £468.25
DPD Next Day Parcel
VAT is being charged at 20.00% VAT : £96.00
Total : £576.00
you get £20 off the coolermaster silent pro 500w or 600w psu if you buy a coolermaster case(you've chosen the ellite 430). so £556
http://forums.overclockers.co.uk/showthread.php?t=18347004
before anyone says the cm psu is rubbish all I'll say is that stulid has suggested it at least once since the offer started.
if the total is too much then just go for a cheaper cpu for the time being and upgrade in the future.
edit: damn it boxer while I was typing :(
Your basket
(£119.99) £143.99
(£119.99)
(£83.32) £99.98
(£83.32)
(£79.99) £95.99
(£79.99)
(£33.32) £39.98
(£33.32)
(£33.32) £39.98
(£33.32)
(£29.99) £35.99
(£29.99)
(£14.15) £16.98
(£14.15)
Sub Total : £394.08
DPD Next Day Parcel
Total : £487.00
you can save £15 by going for the z68ap-d3 as no way you can xfire on the 530w psu. change the psu to the cm silent pro(its modular so easier cable management) and you've basically got the same spec as me(if you change the i2500k in my spec to the cpu you've chosen it'll identical)
does that psu have 2 6 pins? if so, very nice, a total £40 increase is well within reason if you think that this cpu and board would be better
edit: that was at shadow boxer, appreciate the help aswell fowler* (sorry :)) but im just looking at what i need for now
edit: that was at shadow boxer, appreciate the help aswell follower but im just looking at what i need for now
as I said in my spec just drop the cpu down, the psu I've got is modular and more 'juice' which gives you a bit extra 'headroom' for higher spec graphics card + other upgrades. coss the same as well when you use the voucher code.
@fowler002 - agree that the Cooler Master Silent Pro Modular is a good PSU but I think it probably pushes the budget up a bit too much, esp with an i5 2500K, but getting the i3 instead could be decent option. The Gigabyte Z68AP-D3 will be fine too, gets good reviews and will save you £15.
@fowler002 - agree that the Cooler Master Silent Pro Modular is a good PSU but I think it probably pushes the budget up a bit too much, esp with an i5 2500K. The Gigabyte Z68AP-D3 will be fine too, gets good reviews and will save you £15.
how many time do I have to say it DROP THE CPU DOWN TO THE I2100 if the i2500k is too much. the psu is also the same price as the be quite you've speced as they have the £20 off offer(be quite + case £40 + £40 = £80, cm silet pro + the case £60+40 = £100 - £20 = £80)
my spec comes to £472 if you drop down to the i2100 same as yours if you change down to the z68ap-d3
edit: changed the cpu
(£119.99) £143.99
(£119.99)
(£79.99) £95.99
(£79.99)
(£70.82) £84.98
(£70.82)
(£49.99) £59.99
(£49.99)
(£33.32) £39.98
(£33.32)
(£29.99) £35.99
(£29.99)
(£14.15) £16.98
(£14.15)
Sub Total : £398.25
DPD Next Day Parcel
VAT is being charged at 20.00% VAT : £82.00
Total : £492.00
cmdouble code knocks another £20 off so £472(£84 less than the i2500k spec)
oh forgot to mention new graphics cards are just around the corner and not all will cost £500+, there will be sub £200 card in the coming weeks which if the reports are correct will have 6970 matching performance.
jpod the 6870 is the best i could afford :p anything higher and the price starts to jump considerably
and thanks to you others, end spec looks very nice indeed, just wondering how long that cooler master code is gona last since i dont have enough to buy just yet, and im still in need of a new hdd (no idea when this will happen since the prices are still too steep)
Calm down, your gona give yourself a coronary!
Stealth edit earlier!:p
well the ode has been active for the past 2 weeks, no mention of a end date in the thread I linked to.
