New Build - first on in 5 years
18 Oct 2002
London
My basket at Overclockers UK:
Total: £981.16 (includes shipping: £12.30)​
Current plan is to reuse my Corsair CS850M 850W Semi-Modular 80+ GOLD and XFX Radeon R9 390 from my current machine. Advice and possible savings welcome.
Gpus are available if you go down the route of a pre build.
what sort of work do you do on the pc and also what res you plan to game at?
Here’s a prebuilt with a 3060ti, I’ve altered the specs to match your original component choice as closely as possible.
  • 1 x OcUK Gaming Oxygen Gaming PC - AMD Ryzen 5 5600X, GeForce RTX 3060Ti = £1,660.98
    • Primary Solid State Drive (M.2):WD Blue SN550 1TB SSD NVME M.2 2280 PCIe Gen3 Solid State Drive (WDS100T2B0C)
    • Secondary Solid State Drive (M.2):Unwanted
    • Primary 2.5" Solid State Drive:Unwanted
    • Secondary 2.5" Solid State Drive :Unwanted
    • Operating System:Unwanted
    • Security Software:Unwanted
    • WIFI:Unwanted
    • Case:be quiet! Pure Base 500 Midi Tower Case - Grey Tempered Glass
    • CPU:*Build Stock* AMD Ryzen 7 5800X Eight Core 4.7GHz (Socket AM4) Processor - Tray
    • Memory:Kingston HyperX Fury 16GB (2x8GB) DDR4 PC4-28800C17 3600MHz Dual Channel Kit
    • Graphics Card:*Build Stock* MSI GeForce RTX 3060 Ti VENTUS 2X OC 8GB GDDR6 Graphics Card
Total: £1,675.08 (includes shipping: £14.10)​
Thanks but I've already got the CPU and RAM 2nd hand and have the ability to be patient rather than overspend on a 3060 and hopefully pick up either a 3080 or 6800 when they exist. I have the issue of trying to save money and also wanting a relatively high spec.
After saving cash
Total: £402.22 (includes shipping: £12.30)
Though spend £10 more on
https://www.overclockers.co.uk/wd-b...-solid-state-drive-wds100t3x0c-hd-55v-wd.html
Case is better for silence
