looking to build new system for 1440p gaming as current system struggles with my new monitor, and would like some advice/reassurance as haven't been keeping up with things for a few years.
current plan is pre-clocked bundle and new GPU below:
CPU/Mobo/RAM: krypton Z77 i5 overclocked bundle
- i5 3570K @ 4.4GHz
- gigabyte Z77-D3H motherboard
- 8gb ram, Samsung green PC3-12800C11 @ 1600MHz
- prolimatech megahalem + fans
(on special offer at moment so cheaper than components alone and someone else messes about with heatsinks and o/c
GPU: Gigabyte GTX670 Windforce 2Gb
- so many brands to choose from, but this one seems good reviews.
- seems to be some consensus that 4Gb vRam is mostly pointless as gpu will max out before vRam most of time anyway.
- so thinking go 2Gb and maybe SLI another one somewhere down the line if I save up.
- presumably mobo would be ok for SLI 2x670?
total cost £745
PSU question: I currently have corsair HX 520W which has been great - will it be enough for new build? (although I guess for any future SLI definate no)
Assuming new PSU needed I'll stick to corsair I think, but what wattage required?
And that's it I guess. Hopefully this will run stuff at 1440p on reasonably high settings? (One advantage I've noticed already with 1440p is AA often not that necessary, which helps the rate)
Thanks for any advice/feedback and taking time
- i5 3570K @ 4.4GHz
total cost £745
