New Build for 3080
  • Thread starter Thread starter smr
  • Start date Start date
smr
smr
6 Mar 2008
Leicestershire
Hi,
I'm looking for some advice building a new Computer around the 3080 Graphics Card. I think it makes sense to wait for Zen 3 CPUs if they are going to be out before the end of the year, if they're not going to be out until next spring I'll probably buy a Ryzen 3900X now... but here's what I am thinking of so far... I've priced these components roughly around my budget and am hoping they're compatible with everything.
https://www.overclockers.co.uk/zota...dr6x-pci-express-graphics-card-gx-122-zt.html
My basket at Overclockers UK:
Total: £509.03 (includes shipping: £11.10)​
The Motherboard has what I think are 2 8 pin (6+2) PCIe connectors with PCIe Gen 4 Support. Presumably the Motherboard's bios will be updated to support Zen 3?
What do you think to these components, are there better for around the same price of each etc?
I would get the corsair rm it has a 10 year warranty.
They should work well together, for true compatibility you have to check the msi website qvl list
I would get a 3700x and then wait for zen 3
If you don't want rgb ram then the corsair lpx is cheaper.
B550 boards are cheaper but have a less usb, m2 slots.
