New build for a friend
7 Apr 2013
Hi -- Should I change anything on this system build?
Processor: Intel Core I5-3470 Processor (3.20GHZ, 6MB Cache, Socket 1155)
GPU: Asus Nvidia GeForce GTX 780 DirectCU II 3GB GDDR5 Graphics Card
RAM: Corsair CMZ8GX3M2A1600C9 Vengeance 8GB (2x4GB) DDR3 1600 Mhz CL9 XMP
Motherboard: ASRock 970 Extreme3 R2.0 Motherboard
HDD: Western Digital 1TB internal Hard Drive - Caviar Blue (3.5 inch)
CD Drive: Samsung 24x SATA DVD Writer - Black
PSU: Corsair Builder Series CX 600 Watt ATX/EPS 80 PLUS Bronze Power Supply Unit
Case: ADVANCE Hunter X PC Tower Case in black with green LED
Quoted £850
Thanks
Er..... Slight problem there is that the CPU you have choosen will not work with that Motherboard in a month of Sunday's. The CPU is desgined for the Intel LGA 1155 Socket where as the Motherboard is designed for the AMD AM3+ Socket.
I think the rig is very unbalanced and could do with some work and could be improved, what would the rig be used for mainly (I have it that its meant to be a gaming PC)?
I'll be helping.
He just game me the specs and I wanted to know what was the main uses of the new system.
This is my system, so something like mine - Budget £850
Case - Corsair Carbide 330R Silent Mid Tower Case - Black
Processor (CPU) Intel® Core™i7-2600 Quad Core (3.40GHz, 8MB Cache) + HD
Heatsink - Thermalright True Spirit 140 CPU Cooler - NEW
Graphics - Sapphire Radeon R9 280X Vapor-X OC 3072MB
Asus P8Z77-V LX Intel Z77 (Socket 1155) DDR3 Motherboard
Memory (RAM) 8GB SAMSUNG DDR3 DUAL-DDR3 1333MHz (2 X 4GB)
1st Hard Disk SSD 250GB
2nd Hard Disk 1TB SERIAL ATA 3-Gb/s HARD DRIVE WITH 16MB CACHE (7,200rpm)
DVD/BLU-RAY Drive 24x DUAL LAYER DVD WRITER ±R/±RW/RAM
XFX 850W XXX Edition Modular '80 Plus Silver' Power Supply - NEW
