New build for AI, gaming and VR
11 Nov 2003
Cambridgeshire
It's been 10 years since I built my last PC, and it's time for a whole new system. I'm quite out of touch.
It'll be used for AI / ML learning and general coding, so ideally needs decent compute capability. Also will be used for gaming though that's secondary, and PCVR - I have a Quest 3 and would like to tether it.
Budget is £2k to £2.5k (may stretch a bit further potentially) and will need to include a monitor, keyboard (mechanical preferably) and mouse.
I'm thinking something along the lines of a 9700X with a B850 mobo. 64 GB RAM at minimum, and perhaps a 5070 Ti (though I wonder if it's worth waiting until next year when models with more VRAM appear).
Any and all suggestions welcome. Thanks!
Max budget option.
I can't recommend a monitor, mouse or keyboard.
Is your compute mainly on the GPU, or does it use both heavily?
If it uses both heavily, I'd suggest a 360mm AIO rather than the peerless assassin.
If storage is rarely a bottleneck for you, then you could dump the PCI-E 5.0 SSD.
At the moment, I'd just look around for deals because of the recent price increases. If capacity is important to you (and you're actually making good use of it) then I wouldn't care about speed. Note that 128GB (2x64) kits exist now.
My basket at OcUK:
Total: £2,502.77 (includes delivery: £0.00)​
Thanks. At this point, I'm not sure whether I'll be doing compute on the CPU or GPU (though I would expect eventually the latter), so a good all-rounder would be appropriate.
I assume you went for the Intel CPU for its better multicore performance?
AI/ML isn't something I'm super familiar with, but my understanding is that the GPU is mainly used and nvidia is strongly preferred? I'd imagine VRAM (you mentioned waiting for the Supers) would be very helpful too.
Yes. The 265K is a good multithreader. The 285K is a lot more money for not a lot (4 E-Cores), so I discounted it and put the money into the graphics card.
In the end I went a bit over budget and ended up with something like this:
My basket at OcUK:
Total: £2,964.79 (includes delivery: £0.00)​
Built yesterday with no hitches. All seems to be working well so far. Thanka for the advice!
£589 (incl. VAT)
£450 (incl. VAT)
£1,080 (incl. VAT)
£1,050 (incl. VAT)
£150 (incl. VAT)
£130 (incl. VAT)
£243 (incl. VAT)
£196 (incl. VAT)
£130 (incl. VAT)
£110 (incl. VAT)
£64 (incl. VAT)
£45 (incl. VAT)
FREE DELIVERY
