I've prepared a list of parts for my brother (New PC build), as follows:
At the moment, I thought AM5 would be a better platform due to issues with Intel's 13th and 14th generations, in addition to performance issues with the 15th generation.
Also, I like how easy it is to get the most out of Ryzen CPUs, for the most part they will run up to the thermal limit and there's very little tweaking required.
The power supply has a 12 year warranty, and supports the ATX 3.1 standard.
I thought sticking with DDR5 6000 MT/s for now would be better than opting for 8000 MT/s (which requires the memory controller to run at a reduced speed), but the motherboard can support 8000 MT/s.
Not sure if it's worth getting 8000 MT/s at this point. Would like to hear your thoughts on that.
I could include a V-cache CPU, but my brother doesn't seem to think they are worth the cost at the moment, and the availability seems somewhat poor.
We plan on upgrading the graphics card next year, and might get a NVME drive. He has a GTX 1080, monitor and SATA 1TB SSD which he will carry over from his last PC.
What do you think of the choice of motherboard and case?
