I am looking to build a NAS/Windows Home Server system using the above case.
I plan to install 8 HD's but need advice on the other components to put in. Not sure how powerful it should be. It will only be for storing of files, photos and movies. It will also be used to rip blu-rays/dvd's, downloading torrents etc
I want to use it to stream itunes to other computers and for people to stream movies onto their computers so not sure if FreeNAs or WHS is the best to use for this.
I also want it to be setup as RAID
I have a separate HTPC set up that I want to use to stream from the above new build. I have installed XBMC on the HTPC.
Want to spend as little as possible but not compromise the system. Will not be used for any gaming.
Any help is greatly appreciated.
