AMD Phenom II X4 Quad Core 955 Black Edition 3.2GHz (Socket AM3)
Asus ATI Radeon HD 4890 1GB GDDR5 PCI-Express Graphics Card
Gigabyte GA-MA790XT-UD4P (Socket AM3) PCI-Express
Western Digital Caviar Black 500GB SATA-II 32MB Cache
OCZ Platinum AM3 4GB (2x2GB) DDR3 PC3-10666C7 1333MHz Dual Channel Antec 300 Three Hundred Ultimate Gaming Case - Black
Pioneer DVR-216DBK 20x DVD±RW SATA Dual Layer ReWriter (Black)
OCZ ModXStream Pro 600w Silent SLI Ready ATX2 Modular Power Supply
That's the spec. The actual build went well with no problems. I seem to be having a problem with Windows Vista though. I insert the CD, choose to boot from CD rom and then a black screen tells me 'Windows is loading files' and then the 'Microsoft Corporation' screen comes up with a scrolling logo bar. After that there is a light blue background where I can see my mouse cursor (the beginning of the actual Vista installation phase I assume). There is an hour glass next to the cursor for a few seconds then it disappears and nothing happens. There is no crash, because I can still use the mouse but the comp doesn't sound like it's doing anything or loading.
Does anyone have any idea what might be wrong? I'm thinking something to do with the hard drive? It's Sata and maybe I haven't configured it right? Any suggestions would be much appreciated.
