New Build Help/Advice
26 Jan 2017
Just put a lot of effort into a thread and my terrible laptop froze, so frustrated, I try again. (Sorry if its short and sweet). Also sorry mod if this is the wrong forum.
You can see the need for a new build! I have a budget for now of around 800GBP including keyboard, mouse and monitor but can invest more in the future. Main purpose of the build would be gaming, photo editing, video editing and graphic design. I hope for as much upgrade potential as possible and the below list can be totally thrown out if a better build can be suggested for the price.
SPECS:
Budget: 800 +/- GBP
CPU: Intel Core i5-6400K 2.7 - 3.3 GHz
GPU: MSI GeForce GTX 760 Gaming
Motherboard: ASUS H110T
Memory: 8GB HyperX 2133MHz DDR4 CL15 DIMM XMP
SSD: 500GB Samsung 750 Evo 2.5-inch SATA III 256-bit AES
PSU: Corsair CS650M ATX 650 W
Case: Aero-800 Aerocool
Mouse: Logitech G602
Keyboard: Logitech G105
Monitor: Samsung 24”, 1920x1080 Curved Monitor
This build may or may not be compatible, I tried my best to make sure it would be. Please advise? I generally tried to go with vendors and brands I trust. If anyone can suggest changes, subtle or complete different build, please do.
Thanks for taking the time folks, I really appreciate it.
P.S. Does B grade ship to Spain?​
P.P.S. Do I need an adapter to take out my laptops hard drive and put it in the new machine??​
Here's a list I put together on **** that might make seeing the specs a little easier, though the Motherboard isn't correct (closest possible option).
LINK REMOVED
Honestly one or two more might be wrong, if anyone can tell me a better place to compile a list / check compatibility then please let me know.
EDIT:: Linked outside website, will search overclockers.co.uk for list compiler / compatibility checker and post again if found.
Think you might to remove the link. It shows competitors which isn't allowed. Post up your budget and requirements and I'm sure someone will be along to spec you using OcUK stocks.
Thanks Thekwango. Edited & removed. Added because I thought people would be more inclined to assist if they could be linked to each component directly to evaluate.
My Budget and Requirements are both in the second line.
