NEW BUILD HELP CHEERS..
13 May 2008
first of all what I want..ok
1080 gfx and PG348Q ROG Swift 34" 3440x1440 IPS G-Sync 100Hz Gaming
I have budget of about 2.5 to 3k with the next 3 weeks..i don't need a kb/OS etc,,, so basically all I need is the tower and all inside
also id like a SSD for my OS and SSD for my games and maybe a HDD for all the other crap. ..my system will mainly be used for gaming...sorry about the wall lf text...
Some tweaks will be needed, I've not specced in a while! :p
Would you be interested in going SLI in the future? - If so, a better PSU will be needed.
Would you be interested in overclocking? - If so the cooler is up to the job!
Do you also need a windows key? - Add W10.
Z170
My basket at Overclockers UK:
Total: £2,938.81
(includes shipping: £0.00)
As the budget allowed I've added a NVMe drive, however would probably switch that out and go for a X99 - 6800k instead and grab a 250GB SSD for the OS and applications.
X99-V3
Total: £2,962.81
X99 with 2 slower SSD's (but quick enough) and a 2TB HDD for the rest of your files etc.
You can partition the 1TB SSD into 2 x 500GB or 250GB/750GB etc if you want the o/s separate from the games etc.
Ten year warranty with the EVGA G2 psu when you register it.
There is also £55 cashback on the cpu/board from the link Stulid posted above, but the offer expires on the 15th of this month.
Total: £3,013.82
