new build.... help needed
8 Apr 2012
North wales
hi guys been a while since ive been on here now and been playing with pcs mainly due to not being able to afford to do them properly ,
but now im back at work got a cheapish bundle for doing a little gaming and still require some advice
currently i have
Asus M4A88TD-V EVO/ USB3
AMD Phenom 2 x 6 1055T
4 x 2gb ddr3 1333mhz ram
2 x 250 sata hdd's
so need everything else bar the case
thanks
thanks guys
yes ssd definatly needed from what i have read about them , any one ever used the processer /mobo i got and know if there any good fpor a bit of gaming , mw2 ,bo3 etc
If buying new then I would go with intel, but since you already have the phenom then there is no point swapping over, I would just get a decent cooler and overclock your CPU.
i payed £90 for the motheboard , ram , processor, heatsink , 2 x 500gb hdd s and in a case working so thought it not a bad base to work on
Glossy black will pick up finger prints and look awful after not long. Plenty of elegant looking cheap as chips cases on offer here, take your pick of whatever floats your boat at your budget
good point , will have a browse this eveing .....also looking for somegetting everything right in bios to keep this pc running smooth if any suggestion
