New Build help needed!!
2 May 2011
London
Hi All,
I want to build a pc for epos system so the specs don't need to high at all. Was wondering if its possible to build something around £150 mark.
Also I have a laptop (hp dv6000) that currently has the epos system on it and was thinking if its possible take the HDD out of the laptop and put in the desktop, and will the OS and other software will remain or will I have to install everything again?
Many Thanks
Hi Sage,
Here's a start. The Epos System runs on iPads so this should be better performance-wise.
YOUR BASKET
1 x geil black dragon 4gb (1x4gb) ddr3 pc3-12800c11 1600mhz single module (gd34gb1600c11sc) £32.99
1 x evga 430w 80 plus power supply (100-w1-0430-kr) £31.99
1 x amd a4-6300 3.70ghz (socket fm2) apu trinity dual core processor (ad6300okhlbox) £29.99
1 x msi a55m-e33 amd a55 chipset (socket fm2) ddr3 micro atx motherboard £28.99
1 x zalman t3 micro -atx case usb 3.0 - black £20.99
total : £154.55 (includes shipping : £8.00).
not included: dvd drive. don't know if you need one.
your basket
1 x pioneer 24x internal dvr-221lbk dvd rewriter - oem £13.49
as for the os and programs question, have a look at this link, method one in particular. if you follow that advice, you shouldn't run into any problems experienced at times when moving os drive to a new motherboard.
http://www.sevenforums.com/tutorials/135077-windows-7-installation-transfer-new-computer.html
