- 19 Jan 2010
- Merseyside
Hi, i need some help trying to solve this no post problem, i just finished my new build using second hand parts. i powered on the computer the first time and there was no post. i checked the mobo (asus p7p55d-pro) and it has a red light on the pcie lane, using a 4870, i read online to reset cmos and try again, so i did that and the red light has gone, but still no post.
now when i turn the computer on there is supposed to be a light sequence, cpu red led flash, memory red led flash and then pcie red flash, but it only does a single flash for the cpu led, that should mean the cpu is fine as the led would stay on if there was a problem, but im not sure where to go from here?
regards, Dane
regards, Dane
