Hello, just finished a new build with the following specs:
YOUR BASKET
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - OEM £245.99
1 x Sapphire Radeon R9 280X Dual-X OC 3072MB GDDR5 PCI-Express Card £215.99
1 x Kingston HyperX Blu 16GB (2x8GB) DDR3 PC3-12800C10 1600MHz Dual Channel Kit (KHX1600C10D3B1K2/16G) £109.99
1 x Kingston HyperX 3K SSD 240GB 2.5" SATA 6Gb/s Solid State Drive (SH103S3/240G) £109.99
1 x Gigabyte Z97M-D3H Intel Z97 (Socket 1150) DDR3 Micro ATX Motherboard £82.99
1 x Corsair Builder Series CX 750W Modular '80 Plus Bronze' Power Supply (CP-9020061-UK) £79.99
1 x Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614) £74.99
1 x BitFenix Prodigy M MATX Cube Case - Midnight Black £74.95
1 x Corsair Hydro H60 V2 High Performance Liquid CPU Cooler £59.99
1 x Pioneer 24x Internal DVR-221LBK DVD Rewriter - OEM £13.49
Total : £1,083.36 (includes shipping : £12.50).
Upon starting the system for the first time but before installing the OS, the CPU temp is being shown as 90 degrees celcius in the BIOS and all system fans except the CPU fan are running at about 250-300 rpm only (they are 3 pin non-pwm fans, they are the stock Bitfenix fans).
So I need troubleshooting/diagnostic help. Haven't yet updated bios or attempted to install OS because I'm worried about cooking the CPU. What do you reckon? Could the temp be a false reading? incorrectly seated components? Lack of voltage to the fans?
The system was only on for about a minute before the 90 degrees was shown (and it never showed a lower temp). Exhaust air from the radiator was cool to the "touch".
Any help is really appreciated, can provide more info as necessary.
YOUR BASKET
