31 Aug 2008 at 02:09 #1 osullivanpt osullivanpt Associate Joined 29 Aug 2008 Posts 194 11 Last edited: 2 Jul 2009
31 Aug 2008 at 02:12 #2 jak731 jak731 Soldato Joined 17 Mar 2007 Posts 5,508 Location Plymouth only thing i would say is if you are overclocking try to secure an E0 stepping q9550 otherwise i dont see any problems
31 Aug 2008 at 03:12 #3 Chimerical Chimerical Soldato Joined 21 Jul 2007 Posts 5,488 Motherboard is a bit overkill surely? Unless you're going Crossfire, an Asus P5Q Pro (£93) would be sufficient.
31 Aug 2008 at 10:45 #4 osullivanpt osullivanpt Associate OP Joined 29 Aug 2008 Posts 194 11 Last edited: 2 Jul 2009
31 Aug 2008 at 12:50 #5 Namistai Namistai Associate Joined 29 Dec 2007 Posts 775 Location Shrewsbury Looks good If you're NOT looking to overclock then the RAM is a bit excessive, but I'll assume that you are given the comment on the E0
31 Aug 2008 at 21:59 #6 osullivanpt osullivanpt Associate OP Joined 29 Aug 2008 Posts 194 11 Last edited: 2 Jul 2009
