Thanks for the advice this is my new revised build changed the psu, graphic cards, processor, mobo and dual channel memory. Whats the difference between the p55 and h55 chip-set cos i couldn't see it on the processor.
[pic not repeated]
Just notices the price pretty leet tbh
LOL just put a pretty identical spec together myself! Just the one GPU and an SSD though as it was comparing to your i7 spec.
I would use the Antec PSU as skylineboy suggested as it comes ready for x-fire/sli with 4 6/8-pin connectors and 650W is fine for 2x 6870. Also, for only £1 more get the UD6 as it is an upgrade from the UD4 (should cost a lot more than it really!). Or consider the GD65 if you want to save a bit, but the UD4/UD6 are pretty high end P55 boards and will be great for overclocking and offer a lot of high end features (especially the UD6). The SATA3 in particular will get the most out of an SSD you might add later.
Here was my spec anyway...
MSI ATI Radeon HD 6870 1024MB GDDR5 PCI-Express Graphics Card £194.99
IIyama Prolite E2472HD 24" Widescreen LED Monitor - Black £169.99
Gigabyte GA-P55A-UD6 Intel P55 (Socket 1156) DDR3 Motherboard £151.99
Intel Core i5 760 2.80GHz (Lynnfield) (Socket LGA1156) - Retail £135.11
Patriot Inferno 60GB 2.5" SATA-II Solid State Hard Drive (PI60GS25SSDR) £88.11
Microsoft Windows 7 Home Premium 64-Bit - OEM (GFC-00599) £82.24
Coolermaster CM-690 II Advanced Dominator Case - Black £76.99
Antec TruePower New Modular 650W Power Supply £69.99
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9) £65.99
Razer Arctosa Keyboard - Silver £36.99
Akasa AK-CCX-4002HP Venom CPU Cooler (Socket LGA775/LGA1156/LGA1366/AM2/AM3) £36.99
Samsung SpinPoint F3 500GB SATA-II 16MB Cache - OEM (HD502HJ) £32.98
Samsung SH-S223L/BEBE 22x DVD±RW SATA Lightscribe ReWriter (Black) - OEM £13.99
TP-Link 150Mbps Wireless Lite N PCI Express Adapter (TL-WN781N) £11.50
OcUK Value 2m DVI Male - Male Monitor Cable (DV-106) £7.04
Sub Total : £999.91
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £20.10
VAT is being charged at 17.50% VAT : £178.50
Total : £1,198.51
EDIT: Looks like you are sorted anyway as above. The GD65 seems to be a great board - supported a 4.2GHz overclock in a review i just read. You get a free USB3 card at the mo, and can add SATA3 later too if you add an SSD although that will have all your PCIe slots full, but never mind. Or you can consider the UD6 with USB3 and SATA3 already built in, but it may not really be worth that extra £50. Good luck with the build.
