New Build help please
22 Dec 2013
Hi, could anyone be kind enough to speck me a gaming pc with virus software removal that i can use to remove viruses on other peoples computers. but it is mainly for myself for gaming at ultra settings 4k.
My buget is £2500 and intel or amd welcome.
Many thanks.
Many thanks.
How are you intending to remove viruses from others peoples PC's? and are you in some kind of infected zone where you know lots of people that have them? .... If your talking about removing hard drives and connecting them to your pc to remove/clean them from virisus/malware I would use a cheap 2nd hand PC as a doner PC with a basic build of windows and your choice of AV software. I wouldnt be putting anyone's dirty crap anywhere near my personal gaming PC.. It sounds like you dont much about Antivirus / Malware in the first place.? which also makes this a bad idea
Many thanks.
Wouldn't it be better to install an antivirus program onto the computer of someone who has a virus as it might not only remove the virus on there but prevent future ones, particularly if their use of computers makes them prone to getting a virus. As above l would look at OcUK premade systems given the prices of GPU on their own
