New build help please.
30 Jun 2006
Cardiff
So I am having issues with a new build that I have just completed.
5900x, Gigabyte vision B550 DP, 4x8GB 3600 c18 Corsair dominator ram, Corsair sff 750w and a 1080ti. So after finishing the build I powered it up all the lights and fans spin up. But I get no video output or post screen.
So I went to the gigabyte website got the latest bios which I believe to be F12. Downloaded it, extracted it to usb drive renamed it GIGABYTE.bin and hit qflash plus button. It then blinks fast and it reads the USB drive and then changes to slow blinking and then it eventually stops and nothing. It doesn’t power down or reboot. The error code on the readout is 05. Before that it was 61. When I repower it. I still get no vid output or post screen.
just wondering if there are peeps out there with a similar build who might be able to help.
thanks in advance
If that doesn't work take out RAM sicks no. 2 & 4. I had posting problems with 4 x 8GB Corsair as different manufacturers believe it or not, then manually set speed to 3600 and turn XMP off if you get to BIOS screen. Good luck.
