- 18 Feb 2016
Hello good folk of world OC.
I have an issue with a new build I have recently completed which I would appreciate some advice with if anyone can help? Upon startup I get the following message on a black screen.
“The ME FW of system was found abnormal.
It is recommended to re-install system BIOS by M-Flash to ensure normal system operation.
Press F1 to Run Setup
Press F2 to continue.”
Now then, this happen most often but not all of the time and sometimes hangs on a blank black screen for 30 seconds prior to this message.
F1 goes to BIOS,
F2 loads straight into windows and normal service resumes.
Having spent £400 I would really like my new rig to boot straight into windows when I turn it on, is this too much to ask or am I being unreasonable…..?
Here is what I have done already;
(no overclocking yet what-so-ever)
Updated BIOS to latest version (several times)
Fresh install of windows 10 from ISO,
Updated all drivers from MSI website.
Un-installed the Intel Management Engine driver
Re-installed the Intel Management Engine driver
Reset BIOS via reset CMOS button.
If anyone can suggest a fix for this I would be most grateful. Here is some hardware spec;
MSI
Z170A-G43 Plus Intel Z170 (Socket 1151) DDR4 ATX Motherboard.
Intel
Core i5-6600 3.30GHz (Skylake) Socket LGA1151 Processor - Retail.
Corsair
Vengeance LPX 8GB (2x4GB) DDR4 PC4-19200C14 2400MHz Dual Channel Kit – Black.
MSI
MSI GeForce GTX 285 DirectX 10 N285GTX SuperPipe.
Kingston (C drive)
HyperX Fury 120GB 2.5" SATA 6Gbps Solid State Drive.
OS
Windows 10 Pro x64
2x
WD HDD 500GB SATA storage.
2x
LCD Dispalys (cloned).
Pioneer
24x Internal DVR-221LBK DVD Rewriter - OEM.
F1 goes to BIOS,
MSI
Intel
Corsair
MSI
Kingston (C drive)
OS
Windows 10 Pro x64
2x
2x
Pioneer
