Hi all,
Had my current machine since 2005 I think
(P4 3.4) and it's showing its age, keeps falling over and when it doesn't it still struggles.
Last machine was built for gaming, but I haven't used it for gaming in a long time, use my 360 for that. Looking for a good stable spec (No OC, stock only) as quiet as possible. I will be using XP OS.
Was hoping to re-use some existing components if possible. Can I still make use of these?
Many thanks
S.
(P4 3.4) and it's showing its age, keeps falling over and when it doesn't it still struggles.Last machine was built for gaming, but I haven't used it for gaming in a long time, use my 360 for that. Looking for a good stable spec (No OC, stock only) as quiet as possible. I will be using XP OS.
- Akasa Ultra Quiet 400W Paxpower Active PFC ATX2.0 PSU
- Radeon X800 XT (may upgrade later)
- Intel Core 2 Duo E8500 LGA775 'Wolfdale' 3.16GHz or...
Intel Core 2 Quad Q9300 LGA775 'Yorkfield' 2.50GHz *What would be a good Motherboard to suit those? Why would I be better with one over the other? - Antec Solo Quiet Mini Tower *Really don't need anything bigger
- Samsung SpinPoint F1 750GB SATA-II
- Asus DRW-2014L1T 20x DVD±RW SATA Dual Layer *When it's back in stock
Many thanks
S.
