Okies. Specs in sig.
I put it all together(first intel build) and when i turn it on it turns on ok, but it doesn't display anything to the screen. All the fans spin real fast though. I checked the power to the gcard and its fine.
help!
btw, when installing the conroe, it doesn't "slot in" does it? you just put it there and let the braket thing do the rest of the work with the lever right?
help!
