Hi
Can you please help me decide on the spec for my new build.
At the moment I have narrowed it down to:
EVGA GeForce 8800 GTS SuperClocked 320MB
Intel Core 2 Duo E6700 Conroe" 2.67GHz (1066FSB)
Samsung SM-226BW 22" Widescreen LCD Monitor - Black
Western Digital Caviar SE16 500GB 5000AAKS SATA-II 16MB Cache
Asus P5B Deluxe/WiFi-AP
Lian-Li V-1100 Plus Black V SILENT Deluxe Tower Case
Zalman CNPS9500-AT Aero Flower
620W Corsair CMPSU-620HXUK
Corsair Dominator TWIN2X2048-6400C4D DDR2 / 800MHz 2x 1GB Modules
I am happy with most of my decisions apart from the motherboard, RAM and GPU.
I am aiming for a quiet machine that will mainly be used for graphics work using Photoshop, 3D Max and Maya. I will probably not be playing the latest games but will want to play CS Source. I also aim to do Overclocking. I dont think I need SLI for a while.
Should I be considering a newer motherboard with a higher FSB (1333) and better RAM (8500) with higher speeds? There seems to be little difference in price between my choices and newer higher spec models. Is this a no-brainer or is there more to it?
What do you think about the EVGA graphics card. Do you think it will be overkill for my uses?
My budget is < £1400.
Thank You
Thank You
