New Build Help...
Man of Honour
1 Nov 2006
Lian Li v1000+
ABIT IP35 Pro
Tuniq Tower
8800GTX
HX620W
Loads of questions to ask....but firstly.
1. Do I connect the front fan as the "Sys Fan" (or the rear fan?)
2. Do I connect the onboard Speaker to the "Internal Audio Connector"?
3. I have connected the 24 pin plug and the 8 pin plug, what happens to the 4 pin plug?
....more to follow! :p
Thanks for patience...;)
1. As long as you don't connect it to CPU fan, it doesn't really matter :)
2. Nope, don't think so anyway.
1.8.5 Internal Audio Connector
This connector connects to the audio output of internal CD-ROM drive or add-on card.
3. You may have a 4 pin socket on the mobo (checks abit website, reads manual) no, just the 8 and the 24 connect to the motherboard.
There should be a couple of pins on the motherboard for it (the same place as the power switch, reset switch etc) as far as i know..
Aero
