new build help
1 Jul 2009
I have receieved all of the parts but am having a few problems,
Trying to put the following together
antec 902
overclocked i7 bundle includes:
gigabyte ud5
noctua cooler
so far I have the Gigabyte ud5 in the antec 902 the ram and cpu are installed and the noctua is fitted but I can only find one cpu_fan socket on the board where do i put the cable for the 2nd fan on the noctua? also where is do i plug the leads for hdd led rst sw and pwr sw?
The second cpu fan you need to plug in another fan header.
The HDD LED ect plugs into the F_Panel which is located under the IDE connector. Page 32 & 33 will show you what's what :)
Yea I have read the manual and figured out the switches I just couldnt see the print on the mobo lol. Still dont know where to put the cable for the 2nd cpu cooler though
ok i have plugged one into the cpu_fan and the other into sys_fan3. I have now installed the zotac gtx 285. it came with 3 cables do these plug into the gfx card as i can only see space for one and thats the little one if this needs to be in where does the other end plug into?
