new build help
30 Dec 2011
belfast
Hi folks, just looking for a simple answer to a simple enquiry, looking to build a new system around an i7 3820 or 3930k (2011 socket obv) and have been looking at the ASRock X79 Extreme4 (Intel X79) Motherboard (as im going all black mobo with green fans/alchemy cabling etc) just want to know what the form factor of the board is, as no site ive been to quotes the size (XL-atx/e-atx etc) as im looking to put this into a corsair 800D case, if it is XL-atx, then i might have to consider the new NZXT-switch 810 or bitfenix shinobi XL instead. Finishing touches are the new twin frozr 560ti 448 and OCZ 1000W psu for those who wish to ask, with rasa 750 dual bay pump/res and xspc 360 rad in push/pull with bitfenix spectre fans. If I have to go XL-atx, i may also consider the gigabite UD3 board as well (cant afford a G1 assassin before people say ;) )
many thanks, but i think im blind!
cheers for the reply, i must just be totally blind as i had visited their site! that suits me perfect, ASrock mobo/800D/3930k all lined up to go then :)
