- 28 Aug 2016
A new PC build here and first time too. Finally getting into the PC gaming goodness! So a few questions I hope you can help me out with here
First see link of the build below
** Competitor link removed **
Though I have researched heavily to ensure everything goes together, I’m a little bit worried about the fitting (sizes) of the components in the case and PSU consumption/compatibility of parts. Can anyone lend me a little knowhow knowledge on these? Also I’m assuming the I’m going to need a cooler for cpu as well, Can you advise on a decent cooler? Under £30 preferably.
Secondly is a Disc reader/drive necessary to install things like drivers, windows etc? Or can I use a USB to install the OS and download the drivers?
Will check back for responses tommorow. Thanks.
