New build I5 temperature test - advice please!
22 Jan 2006
I bought an I5, which is my biggest upgrade for some time. These are the temps I am getting:
Idle: 30c
Load: 57c (Prime 95 run for 15 mins on full)
This has not been overclocked yet - I just wanted to know if these temps are ok to start with. I have a Zalman quiet cooler fan.
Your temps look fine - although i would run Prime for an hour as the load temps may rise a tiny bit more - even if they did the temps would still be respectable.
I find core damage raises the temps higher than running prime
Quite possibly, but for a temperature marker, before clocking, 'prime' should be a sufficient base benchmark to work from as no game/app will stress the CPU anywhere near as much/consistently as running prime for an hour.
