New Build issue
2 Dec 2004
Under The Desk, Wales
I bought a new Mobo and PSU from OcUK this week and put it all together.
Turned it on and PSU and fans came on and then went off. Tried again and it worked fine for about 15mins and then it shut down again!
Then, i tried several times but it would power up and then shut off.
PSU is new too and i tested it with a PSU tester and in another rig and that proved to be fine, all working fine!
Tried one ram at a time, still the same issue.
In the end i have RMAd the CPU and MOBO.
Would you guys think it was the MOBO? I honestly cant think it would be anything else after checking the PSU, Ram. HD is an SSD which again, works fine!
Everything was wired up as it should have been.
