Hi Guys,
I've decided to build a new cheap Ryzen setup since the new APUs have been released, Here's the specs:
Ryzen 2200G - CP-3AB-AM
Kingston HyperX 3200MHZ 4GBx2 - MY-26J-KS
ASROCK A320M PRO4 - MB-157-AK
KOLINK 400 Watt PSU - CA-02M-KK
The issue I'm having is that the computer won't POST. I thought this could be an issue with the BIOS version not being up to date with the Ryzen APU's being so new so i managed to get my hands on a Ryzen 1200 to try and update the BIOS. However, the computer is still failing to post. Could this be cause' I need a separate GPU as the old CPU doesn't have onboard graphics?
I've plugged in the motherboard speaker but I'm not getting any beeping coming from it and as far as I'm aware there isn't any LEDs on the board so I'm struggling to diagnose the issue.
I've checked The ASROCK site and it looks as though the RAM is OK for the motherboard
https://www.asrock.com/MB/AMD/A320M Pro4/index.asp#MemoryRR
Thanks in advance for the help.
. Suppose if i can't get a hold of a card I'll have to resort to taking it all out
. I'm aware of the Bridger upgrade that needs to be done first. I recon it'll be on 3.30 2017/11/28 since the other versions are so close together!!
