Hi all, was just building a new computer for afriend which consisted of:
Enermax galaxy 1000W
QX6700
Tuniq Tower
BFG 680i Mobo
4Gb Corsair Dominator 6400 (2, 2x1Gb)
2x optical drives
Seagate Barracuda 7200.10 500Gb Hdd
BFG 8800GTX
Basically got it all plugged in (after it took ages fitting the Tuniq Tower and then the 8-pin CPU Power connector wouldn't fit!) Went to try and turn it on and now nothing! The CPU fans, case fans etc, all spin then turn off, the mobo light (blue)stays on, but I am getting 2 continuous beeps i.e. beep beep, pause, beep beep pause...This is coming from the PSU and after reading the Manual it says it could possibly be borked, anybody got any ideas? Anything I could have missed, connectors etc? I am thinking that its probably the PSU, dont have another I could test it with unfortunately (and also if I did I doubt it would be powerful enough!)
Help
Thanks in advance
Kiz
QX6700
Tuniq Tower
BFG 680i Mobo
2x optical drives
BFG 8800GTX
Help
Thanks in advance
Kiz
