- 6 Oct 2007
hi i am going to make my first build i need to keep my budget low so i am using my old coolmaster 690 case, my corsair 650 and my nvidia 460.
i was looking at
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail
Samsung SpinPoint F4 EcoGreen 2TB SATA-II 32MB Cache - OEM (HD204UI)
Samsung SH-B123L/BSBP 12x BluRay ROM / 16x DVD±RW Lightscribe SATA-II Optical Drive - Black (OEM)
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX)
and i like the reviews on the Asrock Z68 extreme 4gen3 but i do like that you have preset overclocks and coming from somebody who has never overclocked or would not be seeking to overclock to the maximum should i just get Asrock z68 pro3 and save the £50? does this cheaper motherboard have the same preset overclocks?
i was looking at
