Hi all,
Just put together my new build and I have a strange memory issue.
System Specs
i7 860
Gigabyte H55N-USB3
Corsair Value 2GB DDR3 PC3-10666C9 1333MHz
Corsair Value 4GB DDR3 PC3-10666C9 1333MHz
The problem is Windows shows 6.00GB installed but only 3.96 GB useable. I am running Windows 7 64bit and the ram shows as 6GB useable in my AMD system. The ram also tests as fine.
I have tried forcing it to use 6GB of ram using MSCONFIG. I also have no onboard GPU so thats not the issue.
Its single channel ram but it should all be usable.
Any ideas?
System Specs
i7 860
Gigabyte H55N-USB3
Any ideas?
