New build & monitor
5 Aug 2010
Hi all,
I created a thread a couple weeks back asking for some pointers on a new build to replace my current 5-6 year old PC.
Having had a look around at whats on offer, the below is where I have come to. Just curious if there is anything that is immediately worth swapping, and I had no idea on case so just kind of chucked one in.. I assume the graphics will have no issue with clearance? Finally, the only other thing to sort is cooling - I have never done anything except just use the stock coolers but want this PC to run quite quiet. What would the best solution be?
I am also going to be picking a monitor up. The budget for the PC & Monitor is £1500-1600 or so, but I really do know nothing about them. My current one will be a bit of a disappointment having spent out on such a good gaming rig! Any suggestions much appreciated.
PSU - https://www.overclockers.co.uk/supe...0-plus-gold-power-supply-black-ca-013-sf.html
SSD - https://www.overclockers.co.uk/sams...olid-state-drive-mz-75e250b-eu-hd-191-sa.html
HDD - https://www.overclockers.co.uk/seag...64mb-cache-hdd-oem-st2000dm001-hd-335-se.html
MOBO/CPU - https://www.overclockers.co.uk/giga...-6600k-bundle-10-pounds-saving-bu-026-gi.html
RAM - https://www.overclockers.co.uk/cors...hannel-kit-black-cmk16gx4m2b32-my-456-cs.html
GPU - https://www.overclockers.co.uk/msi-...ddr5-pci-express-graphics-card-gx-32c-ms.html
Case - https://www.overclockers.co.uk/phan...black-full-acrylic-side-window-ca-040-pt.html
DVD/RW - https://www.overclockers.co.uk/sams...er-black-oem-m-disc-compatible-cd-162-sa.html
OS - https://www.overclockers.co.uk/microsoft-windows-10-64-bit-dvd-oem-ms-kw9-00139-sw-172-ms.html
Goods total
Delivery costs
Total order value
Total value excluding VAT
Total VAT at 20.00 %
£1,180.82
£0.00*
£1,180.82
£984.02
£196.80
Thanks!
I've only had a quick look but it looks like a solid build. Very capable machine. Since you spent so much on a decent card you'll want a real good monitor, 1440p and above. Check out monitors that run at 144hz with gsync/freesync if you can afford it.
You need a cooler, £15 will get a Rajintek jobbie.
Do you need the dvd drive? you can get Win10 on USB for £10 more, do away with the £13 drive
