New build - need a hand with OC
24 Jun 2009
Hi guys,
You know what would be really good - a noobie guide to setting timings for ram and overclocking your cpu.
I have asked in a few forums how to do this but no luck so far. I know its a lot of testing crashing, testing stabling, testing ect.. BUT I don't want to get to 3.9 or 4.2! I just want to try and get around 3.6 and set up my memory timings.
I know there is many links on the first page and indeed on other websites but its all greek to me.... and before any suggestions on being stupid... I did manage to spend a few days reading guides how to stick a pc together and well... I did it!
All I was looking for was what options to change in bios from stock, what things to change/adjust and bingo - thats all. I know (well I think I know) what programmes to run after to check stability.
Any help would be great.
PJ
I'm not an AMD person so can't help the CPU/mobo side
For the RAM just set it to the timings on the side of the sticks which from a quick google is 9-9-9-24
The tech names are the following (or similar)
DRAM CAS Latency: 9
DRAM RAS# to CAS# Delay : 9
DRAM RAS# PRE Time: 9
DRAM RAS# ACT Time: 24
Quite often they will abbreviate it. In most cases it will be the first 4 settings under the RAM options that need changing
DRAM CAS Latency: 9
so I just go into bios -
advanced settings -
and change....
do I keep it at 1t or 2t ?
Do I change the ration to 1;4?
I need all the info how to do it dude.
200 fsb
19 x multi
1.5 volts
gives you 3.8ghz
goes like stink
Thanks. Don't I have to change anything else in bios at all?... lI found this in a guide somewhere?...
Recommended BIOS Settings:
Disable Cool ‘n’ Quiet
Disable C1E
Disable Spread Spectrum
Disable Smart CPU Fan Control
Manually set Memory Timings
Windows Power Option: High Performance
???? do i have to do the above before I overclock?????
