Just joined the forums to get some insight into this build. I'm going to scavenge one or two components from this PC to reduce costs.
I currently have the following parts for this build:
1. Cooler Master CM-690 II Lite Dominator Case
2. Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
3. My old Blu-Ray DVD+RW Drive
4. My old HDD even though I have no idea what it is.
Now, need a few more items as you can see. I didn't want to spend anymore than another £500 tops on the rest of the components, but I've already gone over that mark with what I have in mind:
1.Asus P8H67-M LE + Intel Core i5 2500K CPU + Performance Fan - I was asked to remove the link to here are the specs below of it:
2. PowerColor ATI Radeon HD 6970 2048MB GDDR5
3. Cooler Master GX 650W '80 Plus' PSU
Works out around £600 with delivery included.
Now I thought the PSU was quite expensive for the brand since I've seen better brands with lower (w). So if you can advise me a cheaper PSU that'll be great. Not even sure if I need 650w.
Also, I've seen i5 2500k being OC'd at 4.6GHz... is the one from PC World actually capable of that without blowing up? It has stock turbo boost to 3.7 but I'd like more. And buying the parts separately in that bundle seem to cost more from Overclockers.
Any advice would be awesome guys! Oh, and I'm only planning on playing with 1 monitor at least 1920x1080 like I do now. Thanks!
Central Processing Unit Includes the brand new Intel LGA1155 Core i5 2500K, 4-Core CPU at 3.3Ghz (Turbo Boost to 3.7Ghz), with up to 6mb of Smart cache 95W
Chipset Intel® H67(B3) chipset
Memory 2 x DIMM, Max. 16GB, DDR3 1333/1066 Hz Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
Expansion Slots 1 x PCIe 2.0 x16
1 x PCIe 2.0 x4
2 x PCI
Storage Intel® H67(B3) chipset: 4 x SATA 3Gb/s port(s), blue
Audio Realtek® ALC 887 8-Channel High Definition Audio CODEC *1 Supports : Multi-streaming
LAN Realtek® 8112L, 1 x Gigabit LAN Controller(s)
USB "Built-in Controller :
2 x USB 3.0 port(s) (2 at back panel, blue)
12 x USB 2.0 port(s) (4 at back panel, black, 8 at mid-board)"
Special Features ASUS EPU :
- EPU
ASUS Hybrid Switch :
- Core Unlocker
- Turbo Key
TurboV
ASUS Exclusive Features :
- MemOK!
- AI Suite II
- Anti-Surge
ASUS EZ DIY :
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
- ASUS MyLogo 2
Overclock Features GPU Boost: Upgrade your graphics performance by up to 48%
Back Panel I/O Ports 1 x PS/2 mouse (green)
1 x DVI
1 x D-Sub
1 x HDMI
1 x LAN (RJ45) port(s)
2 x USB 3.0
4 x USB 2.0
3 x Audio jack(s)
Internal I/O Connectors 4 x USB 2.0 connector(s) support(s) additional 8 USB 2.0 port(s)
2 x SATA 6Gb/s connector(s)
4 x SATA 3Gb/s connector(s)
1 x CPU Fan connector(s)
1 x Chassis Fan connector(s)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s)
BIOS 32 Mb Flash ROM , AMI BIOS, PnP, DMI v2.0, WfM2.0, SMBIOS v2.5, ACPI v2.0a
Accessories User''''s manual
I/O Shield
1 x SATA 3Gb/s cable(s)
1 x SATA 6Gb/s cable(s)
Form uATX Form Factor
1 x PCIe 2.0 x4
2 x PCI
- EPU
- Core Unlocker
- Turbo Key
TurboV
- MemOK!
- AI Suite II
- Anti-Surge
ASUS EZ DIY :
- ASUS EZ Flash 2
- ASUS MyLogo 2
1 x DVI
1 x D-Sub
1 x HDMI
2 x USB 3.0
4 x USB 2.0
3 x Audio jack(s)
1 x System panel(s)
I/O Shield
