new build need help with psu
12 Jun 2011
at my pc
hi guys im venturing in to the world of pc building & modding here is my list of components
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor
Asrock Z68 Extreme4 Intel Z68
OCZ Agility 3 60GB 2.5" SATA-3 Solid State Hard Drive
Fractal Design Define R3 Midi Tower Case
Corsair Hydro H60 CPU Cooler
Samsung SpinPoint F3 1TB SATA-II 32MB Cache -
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
Pioneer 24x Internal S19LBK DVD
the reason i write to you to day is because im not sure on what psu to get. as i wont to buy one soon so i can braid all the wires while i save the rest of the cash for the other components.
many thanks for any advice
p.s im not getting a gpu straite away but mite do later
what sort of PSU do you want. A normal, all leads attached or a modular one to keep the case tidy?
defo modular as im braiding all the cabels
thanks for your advice
Those dont really leave the PC with much room to upgrade if he adds a high-end graphics card later down the line. I thinkl you should think about something bigger. An 850w will leave you with plenty of upgradeable capacity down the line.
i dont think i'll be gettig a high end card as i dont play games much any more.
does any one know the best place to get the braiding
