- 10 Jul 2014
So the time has come to upgrade my Socket 939 system (yeah I know, it's a dinosaur). It's been a while since I've dealt with stuff so I could use some input. Here's what I'm thinking of getting:-
CPU: AMD FX-6300
MB: Gigabyte 970A-UD3P
RAM: 8GB Kingston HyperX Genesis 1.6 Ghz
SSD: Intel 335 240GB
GPU: GTX 650 (current card, plan to upgrade to a GTX 760 at a later date)
PSU: Corsair RM650
Case: Zalman Z1
Am I doing it right? Will that memory work with that motherboard? Will that CPU bottleneck a GTX 760? Is a 650 watt PSU overkill? Are the two 120mm fans in that case going to be sufficient?
CPU: AMD FX-6300
PSU: Corsair RM650
Case: Zalman Z1
