- 25 Mar 2022
- Scotland
Hi all first post here.
Got my new kit through from OCUK rapid as ever. However for the first time ever I've got a no-post.
I'm a VERY careful and experienced builder. Checked all the latest guides here in this forum. Triple check all my connections, component fitment etc...I can see nothing indicating i've screwed up the build.
So here's what I got:
12700K
Gigabyte Z690 Aero G
Corsair Vengence 5600 2x16GB DDR5
Corsair RMx 850
Here's the problem I get:
No Post and Status LED's flash backwards and forwards between CPU and DRAM, then after about 30-40secs the system resets itself. (I got about 4 beeps also just prior to it resetting). All fans come on etc...
Judging by one other similar post, I should update the BIOS with Q-FLASH to see if this is causing a RAM problem....So I tired this; but not wanting to disassemble my build without confirming the fault first with the CPU, RAM, M.2 are all still instilled. I popped the pre-loaded USB in to the port labelled USB 3.2 BIOS, pressed the Q-flash button on the MOBO but it all it did was the fans spun into life for a few secs then died. So first question is: Does Q-flash need to be run on a bare MOBO with just a power cable attached?
Is this the wrong avenue and something totally different is at fault?
If the CPU, DRAM, VGA was faulty would a status LED not be on solid? (they are not on solid)
Any help very appreciated, very worried and just spent a lot of money!!
Marco.
12700K
Corsair RMx 850
Marco.
