Just upgraded my old Opty 175, A8N32-SLI and Ram to a E4300, P5N-E SLI and 2 GB 5400 Balistix RAM.
Rest of spec is:
ET850 PSU
7900 GTX
X-Fi Fatal1ty
2 X WD Raptor 36
1 X WD Caviar 250 GB
I put everything in, the only trounble was the NH-U12F in which I cought the motherboard slightly with a screwdriver. There is a small mark anout 3/4 " long on the surface, but whether it's cut the tracks or not I'm unsure. It's not near any somponants, but I can see small tracks on the board.
With my ET850 PSU, it powers on then down about 2 secs later, and I can do this as many times as I want and no change. I had this on the previous board but one day it decided to work and I never had a problem since, I also upgraded the BIOS on the old board.
If I put in my mates Hiper M 580 it powers up and stays on, then nothing. Just power and no post. Only time I can get it to beep is if I remove both sticks of RAM and the GFX card then I get one long followed by two short beeps which is VGA error.
Decided to try my PSU again and now it doesn't power up, instead it switches the light on the back of the PSU to red and stays like that untill you disconnect AC for about 10-15 secs.
What could be the problem? RMA the PSU and motherboard?
Also, I heard a dogy buzzing noise from the PSU for a split second when I moved the swith from on to off.
Rest of spec is:
ET850 PSU
7900 GTX
X-Fi Fatal1ty
2 X WD Raptor 36
