New Build, No Signal
30 Nov 2005
London
Merry Christmas everybody!
a mate of mine has specced a system through overclockers and had it built with them, it delivered on wednesday. He has only just opened it up for Christmas and plugged everything in. When he powers it up he just gets a black screen.
The monitor i splugged in and connceted to his sytem via DP. When he selects the input source via the monitor it seems to accept his choice but does nothing else. I'm having to replay this info via the forums as he is awaiting his application to be accepted by the mods. As much as I can ascertain the system is powered up.
I'm not massivley PC savvy but have been trying to help. Is there anything people could recommend we try to get his system up and running?
He sent me the spec through on email.
OcUK Tech Labs Skylake Z170 Pro Gaming PC Configurator 1
Intel Core i7-6700K 4.0GHz
HS-038-CS Corsair Hydro Series H100i v2
MB-651-AS Asus Maximus VIII Hero Intel Z170 (Socket 1151) DDR4 ATX
Corsair RM Series RMi 850 '80+ Gold' 850W Modular Power Supply
Asus Strix RAID Pro 7.1 PCI-E Sound Card
Asus PCE-AC88 Dual-Band AC3100 Wireless PCIe Adapter
MS Microsoft Windows 10 64-Bit DVD - OEM
Samsung 1.0TB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D
V-NAND Solid State Drive
Corsair Vengeance LPX 16GB (2x8GB) DDR4 PC4-24000C15
3000MHz Dual Channel Kit - Black (CMK16GX4M2B30
Asus GeForce GTX 1080 DirectCU III Strix
Corsair Obsidian 750D Airflow Full Tower Case - Black
HD-22D-SA Samsung PM961 Polaris 256GB M.2-2880 PCI-e 3.0 x 4 NVMe
Solid State Drive
Thank you
B
I assume he has connected up anything inside and/or done anything that might be required with the heatsink? sometimes pre-built systems are shipped with the heatsink disconnected and secured for transit so the board doesn't get damaged, etc.
Standard things like clearing the CMOS either via the jumper or removing the battery for a few minutes comes to mind.
thanks for your promt reply Rroff. I have just got off the phone to him. He is going to wait until wednesday when Ocuk are open again. It is his first PC and doesn't want to be tinkering with it really, which is fair enough. Thanks for your fast response, enjoy the rest of your christymas day. Appreciate the help.
B
