- 5 Sep 2003
- Cardiff Geordie
I've just transferred a system from a server rack case into a standard desktop case. The motherboard is an ASRock 4Core1333-FullHD which has onboard video with 2 x outputs, one DVI and one VGA for dual monitor setups - my monitor is currently under repair so I'm having to use a backup which only has VGA input. Unfortunately, connecting the monitor to the machine via VGA cable doesn't seem to show any output... the monitor just shows 'no signal'. i'd use DVI if I could, in fact I even have a DVI to VGA dongle from an old graphics card but it doesn't quite seem to fit the DVI port on this motherboard (i realise people now call it D-Sub and DVI-D but I don't know what the difference is!)...
It seems as if the motherboard is set to only output via VGA and nowhere in the manual does it mention how to get it to switch to the VGA output as default...any ideas?
UPDATE: The plot thickens....in my haste to get the new machine up and running, I neglected to notice that it wasn't even beeping when powering up.... all lights are on, hard drives are spinning up, fans are whirring.......nobody's home..... I'll open her up and triple-check everything but....any preliminary suggestions?
