New Build - Not posting! Please help!
Hello all, thanks for the help
I recently built my new rig after ages of waiting, and it all worked fine, but then, it went wrong.
The setup is;
E4500 Processor
Gigabyte GA-P35-DS3L Intel P35 Mobo
ATI 3870 XT GPU
2GB Giel Ultra low Ram
Better cooler than stock
160 and 400GB Sata HDDs
500W OCZ PSU
Everything there is within around 2 weeks old except the 400GB HDD.
I build it all, and powered it up, worked perfectly, installed XP and a few programs, then powered it off to plug in the case fans. But after that,the problems started!
It powers up, for about 3 seconds, and then powers off for about another 2 second, and then repeats.
I've tried everything I can think of;
Cleared CMOS by shorting the pins, and also removing battery overnight,
Booting with 1 stick of ram, different slots, different stick, you name it,
Booting with 1/2/no HDDs, tried old IDE drive aswell,
Taking everything off the board, I mean everything except the CPU + cooler!,
Removed board from case and rebuilt from bottom up,
Powering on by shorting the power pins,
I can't think of anything else that could have done it!
If I remove the 12v ATX cable from the top of the mobo it stops resetting, but doesn't do anthing else, so that's no help.
Please help me! Im sure someone far more knowledgable than I am can shed some light on this for me, as I'm getting very depressed by it all now!
Thanks
The setup is;
E4500 Processor
ATI 3870 XT GPU
500W OCZ PSU
Thanks
