- 22 Apr 2011
- Nottingham
Hi all
I have built a (almost all) new system, See sig. and everything is working fine except I keep getting this occurrence..
When gaming (MW2, Dirt 3) I get random lines flash about, Thin lines across the screen, top, bottom, middle etc. I took a photo of 1 to try and help identify this problem. Although not very clear I will post it.
Sometimes, Infact most of the time this doesnt happen, PC has been up and running about 2 weeks and its happened about 5-6 times.
When it has happened I exit the game and it does it when I'm in Windows, When I move a window or do something it will happen for a splitt second then stop, Untill I reboot then its gone altogether.
CPU temp under load - 65c (prime95), (55-58c gaming)
GPU temp maxes around 64-68C.
I have tried different power cables on my 6970, Re-inserted it. Turned vsync off.
Could this be a driver issue? I'm on the latest, W7 x64.
Cheers
Cheers
