New build nothing happens
10 Nov 2011
Telford
Just put together an am1 5150
Msi am1i
2gb ram
500w psu
All put together press the power button nothing.
Check all connections
Dis the paper clip in the 24 pin and the pau starts
Tried the power button off my main rig nothing
Took it out the case to try it open still nothing.
Any ideas what it could be?
Yeh done that.
Have managed to get it to come on now from power button pushed the 24pin down a bit harder but no display to any monitor over dvi or hdmi. No signal
Is the battery not that black round thing with two wires coming out going into the little header on the board?
There's usually a jumper mate where you have to remove the cap and short the pins. Check the motherboard manual :) It should be next to the mini PCIE slot entitled "JBAT1".
Its the board.
It doesnt need a BIOS update, the release BIOS supports that CPU.
Try one other PSU then its looking like the boards at fault.
