- 26 May 2014
Hi all
Looking at branching into PC gaming but need some advice.
I've got a build put together but as a novice just want to make sure there are no glaring mistakes or silly decisions. All of the components I've selected I can get very cheap from a buddy who works at a component store. The only issue is that the store is small and has limited options. This will be mainly for gaming/streaming. Are there any major things you would change? Have I made any mistakes?
Thanks in advance guys
CC-9011052-WW Carbide Series SPEC-03 RED LED Mid Tower Gaming Case
Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor
GIGABYTE WindForce GeForce GTX 770 OC 2048MB GDDR5 Graphics Card
Gigabyte Z97-D3H Intel Z97 (Socket 1150) DDR3 ATX Motherboard
Corsair Vengeance Pro Silver 8GB (2x4GB) DDR3 PC3-14900C9 1866MHz Dual Channel Memory
120GB Samsung 840 EVO Series 2.5" SATA 6Gb/s Solid State Drive SSD
2TB Seagate Barracuda ST2000DM001 3.5" SATA III Hard Drive
Samsung 224DB 24x DVD Re-Writer - SATA - Black - OEM
650W Corsair RM Series 80PLUS Gold Modular Power Supply
Scythe Ashura Performance CPU Cooler
120mm Corsair Air Series SP120 PWM (Twin Pack) Performance Edition 4-Pin PWM Fan
TP Link TL-WN881ND 300Mbps Wireless N PCI Express Adapter
