Hi and just seeking confirmation or critique. Having not built anything since a 4570k and my present system being a prebuilt (10400F with a 3060TI) I'm very out of sorts with the present gear and have gotten myself in a loop.
Looking at building a new system, the idea being it is powerful enough to bump me a few of generations again. I'm not fussed about inter generation up gradability as in practicality, you just end up swapping the lot out in the jump anyway, I'm not a perpetual tinkerer.
As such and with some minor research (Frame chaser lunatic, reddit etc) I've ended up selecting the following:-
Lian Li 216 case (Purchased)
14700K (Purchased)
Arctic liquid rev 2 360 (Purchased)
990 Pro 4TB (Already owned)
Mobo option - Z790 Aorus elite Wifi 7 (8k Ram speed support apparently)
Ram option 1 - Team group T force delta 32GB 7200
Ram option 2 - G skill Trident Z5 32GB 7200
PSU option - Corsair RM1000x
The GFX option will likely be a super 4080 or 7900 XTX a bit further down the line, for now I'll just drop the 3060 in to tick it over till I pull the trigger on that.
I was hovering over the mobo and Ram in the basket but having doubts didn't pull the trigger. I'm reading how memory speed and mobos with DDR 5 are a bit of a minefield. I vetoed Asus due to their customer care issues but when you look into it, it appears most seem pretty poor.
Am I asking for trouble by going for fast RAM and board, is it actually necessary or overkill?
Use case is mainly gaming including VR (worse than 4k) which my present system struggles at.
If you got this far, cheers for reading.
14700K (Purchased)
